GP KICKSTART REASSEMBLE
Posted: Wed Feb 22, 2017 6:11 pm
by dazblakey
Anyone know of a how to post on refitting a gp 150 kick start reassemble please
sent from over there next to the tree
Re: GP KICKSTART REASSEMBLE
Posted: Fri Feb 24, 2017 10:27 pm
by dazblakey
Any help please
Posted: Fri Feb 24, 2017 10:34 pm
by rosscla
What do you need to know?
Sticky's Spanners Manual is the best £20 you'll spend on your Lambretta.
Posted: Fri Feb 24, 2017 10:56 pm
by dazblakey
Yeah bought that, when you put the casing back on do you have to have the lever depressed down then release once the casing is engaged
Posted: Fri Feb 24, 2017 10:59 pm
by Muppet
dazblakey wrote:Yeah bought that, when you put the casing back on do you have to have the lever depressed down then release once the casing is engaged
gp side case yes or plunger pushes side case away
Posted: Fri Feb 24, 2017 11:03 pm
by fairspares
Only if you have GP type endplate but then you only need to press kickstart shaft slightly to clear the ramp lower part.
Posted: Fri Feb 24, 2017 11:06 pm
by dazblakey
Ok guys thanks I think I understand
Posted: Fri Feb 24, 2017 11:13 pm
by fairspares
With li type ramps built into the side case the kickstart plunger is already pushed in after assembly , with GP casing using GP endplate as the casing goes on the plunger will hit the lower part of the ramp so you need to move the kickstart shaft round slightly to clear the ramp once on when you let go the plunger pin engages in the ramp moving the plunger same goes for removing the casing .
