When POR15 goes wrong.............
Posted: Sun Feb 19, 2017 1:05 pm
Have recently had a mid range tank powder coated, decided I'd seal the tank as well with POR15.Anyway didn't go to plan, whatever I did it went t*ts up.The sealant was coming off after it had dried for 5 days in a film, but the main thing is there's a lump of the stuff left in the tank.I'm not blaming the POR15 as I have done about 3 tanks and various oil cans (the Castrol type) over the years all been spot on.Obviously something I have done or it didn't cure right and when I thought I'd got all the excess tank sealer out and left it to dry - I hadn't hence it pooled and now I'm left with a lump of the stuff clanging around in the tank.
Anyway things I've tried so far (I'm resigned to the fact I'll have to get the tank re-powder coated) caustic soda - removed all the film but not the lump.I've tried breaking it up with a large screw driver its solid no joy! I have been in touch with POR15 they recommend aircraft stripper - had a look at the prices of the stuff on the interwebs would be cheaper to get a new tank.Have also tried the handful of nuts and bolts and shaking the tank around.
Any suggestions? I know "normal" paint stripper ain't going to do it as the main ingredient methylene chloride has been taken out over here (hence why Nitromors doesn't burn your hand anymore
