polini 210 help
Posted: Sun Feb 19, 2017 10:13 am
by p2nm
Hi all
just purchased the latest polini 210 kit,is any body else running one that coud give me help with timing,jetting etc
to start i will running standard 24/24 carb with sip road exhaust.
any help appreciatted
Re: polini 210 help
Posted: Sun Feb 19, 2017 10:39 pm
by drunkmunkey6969
You still running standard jetting?
Re: polini 210 help
Posted: Sun Feb 19, 2017 10:57 pm
by p2nm
hi
was looking to up the main jet to around the 128 mark,was interested in what others were running that plus timings
cheers
Re: polini 210 help
Posted: Mon Feb 20, 2017 10:33 am
by drunkmunkey6969
Set timing to 18 (IT mark) check what pilot, atomiser, air corrector and main are.
I
Re: polini 210 help
Posted: Thu Feb 23, 2017 8:56 pm
by p2nm
cheers mate
jets in the carb at present are 55/160 pilot /be3 atomiser/air corrector 160 was looking for advice on main as polini say 120 -125 which i thought would be on the lean side from what others have said,will the head bolts torque setting be the same as the cast iron kit?
thanks
Re: polini 210 help
Posted: Fri Jan 18, 2019 5:26 pm
by eibargum
What carb settings did you end up with.
