damaged crankshaft oil seal face?
Posted: Tue Feb 14, 2017 3:17 am
I was removing the bearing collar by dremeling a notch in the collar and using a chisel to tap it off when I slipped and scuffed the taper,
as you can see where I've circled the scuff - its quite near the flywheel side seal, its not a deep mark but you can pick it up if you run your fingers over it, is it knackered and would damage the seal or could I smooth it down and use it? thanks Paul
