ACF 50
Posted: Mon Feb 13, 2017 8:36 pm
Thought I would flag this up in case there's someone that's not heard about it. It was featured in Scootering Mag a few years ago and I use it. Ps no connection with Bedspeed it came through in an email and although I've not checked the price it seems good value unless someone knows better
Anti-Corrosion Aerosol Spray - ACF-50 - 369gr.Anti-Corrosion Aerosol Spray - ACF-50 - 369gr.
[Adams-ACF-50] £14.99
Delivery Band: _ D
Delivery Price: £5.99 (Minimum delivery charge of £2.00 per order)
Anti-Corrosion Aerosol Spray - ACF-50 - One can 369grams.
As close to zero corrosion as nature will allow
"When applied ACF-50 forms an 'Active' ultra-thin clear film that will kill any existing corrosion cells and will protect your bike against new corrosion forming. On areas such as switches or under the tank and seat, one application will last up to 12 months. Other more exposed areas will need topping up more regularly. ACF-50 has the ability to 'chemically neutralise road salt' and water will bead on contact and literally bounce off. Ideal for the bike that is used all year round in all weathers, a superb service spray as ACF-50 is also a lubricant and penetrant (without loosening structural attachments) and if you put your bike away for the winter, applying ACF-50 will ensure that moisture will not be allowed to cause any damage! Untreated moisture will creep into cracks and will not freely evaporate - ACF-50 actively ejects moisture from these areas"
The Facts
Kills existing corrosion and prevents new
'ACTIVE' for up to 12 months
Excellent lubricant and penetrant
Approved for use on electrics and engines
Easily applied non-drying, ultra thin, clear film
Very economical
Contains no wax, silicon, Teflon or water
"ACF-50 (Anti-Corrosion Formula) was originally designed to protect aircraft from existing and new corrosion and is now available to motorcyclists. Aviation products have to meet rigorously high standards and ACF-50 not only meets these but has been awarded Aviation approvals - MIL-SPEC 81309 types II and III which means it is 'approved for ferrous and non-ferrous metals, electrical systems and electronic components'. The US Navy carried out tests using ACF-50 on the jets on their Aircraft Carriers. They found that ACF-50 so significantly reduced the corrosion they had previously experienced they now use ACF-50 all the time!
It works perfectly in that type of harsh environment so imagine how well it's going to protect your bike!"
Multiple Product PDFs available to view - just select the PDF logo/s at the top of this listing.
Cannot be shipped abroad.
Add to Cart
Submit
Tell a Friend
Product Questions
No Product Questions yet.Ask a question
Monday 13 February, 2017
All original content copyright Beedspeed 2016| All rights reserved | Contact Us | Terms & Conditions | Delivery
Beedspeed Ltd, 109/111 Corporation Rd, Grimsby, N. E. Lincolnshire, DN31 1UR, England.
For all enquiries please call us on 01472 355 558 - e-mail: [email protected] Vat No. GB158223021Company No. 8435162
This site uses cookies. By continuing to browse the site you are agreeing to our u
Delivery Band: _ D
The Facts
Very economical
Add to Cart
Submit
Tell a Friend
Product Questions
