Malossi 166 long stroke
Posted: Sun Feb 12, 2017 11:14 am
by ducksta
Hi guys anybody run a malossi 166 kit with a 60mm crank if so what carb/exhaust set up and how does it run
Re: Malossi 166 long stroke
Posted: Sun Feb 12, 2017 10:20 pm
by ducksta
Anybody?
Posted: Sun Feb 12, 2017 11:50 pm
by rosscla
Is that not what Dan is doing with his dyno donkey articles?
Posted: Mon Feb 13, 2017 10:19 am
by ducksta
I need feedback on the malossi kit
Posted: Mon Feb 13, 2017 9:58 pm
by ducksta
Any other takers
Posted: Tue Feb 14, 2017 8:27 am
by OzOAP
I run a Malossi 166 with a 200 60mm crank. So long stroke/long rod. Packplate under barrel, modify piston windows to line up with ports. 30mm phb carb, PM pipe.
19hp on PM dyno. Goes well. Engine was my rally hack for many years with PX125 gearbox/P2 primary, now in scootercrosser frame with T5 primary.
Posted: Tue Feb 14, 2017 7:08 pm
by ducksta
Posted: Tue Feb 14, 2017 7:32 pm
by ducksta
P2 primary is?
Posted: Tue Feb 14, 2017 9:53 pm
by Muttley McLadd
65/23
Posted: Sat Feb 18, 2017 7:18 pm
by ducksta
Just finishing the build. Malossi 166 barrel tuned head opened up 60mm Mazz crank casings ported/matched drt reed valve 28mm dellorto with built in power jet and a sip road 2
