Tyre removal vice
Posted: Thu Feb 02, 2017 12:01 am
Will clamping a tyre tight in a vice likely to damage the wall, when attempting to remove off a split rim. Tyres are new, but now thinking to respray rims. Thanks
The UK's No1 Lambretta & Vespa Scooter Forum.
https://www.scooterotica.org/forum/
You were quite lucky, they often stick either with rust or paint. I use a workmate to break the bead on tubeless or tubed and not had nay problems. Another method is standing on the tyre with it laid flat and putting your weight on your heals.fluff34567 wrote:Why do you need a vice? I just unbolted the rim and pulled the 2 pieces apart.
Yep you was robbed .... http://www.ebay.co.uk/itm/bNew-Top-Qual ... 2815524590davla wrote:........... you can probably get it cheaper.
http://www.ebay.co.uk/itm/PROTOOLS-Tire ... Swx-9Wzp3Q
I wasn't robbed as I only paid 25 quid for mine, I just posted the first one I came across on eBay to illustrate my point. They're bloody great imo, makes splitting a rim really easy.corrado wrote:Yep you was robbed .... http://www.ebay.co.uk/itm/bNew-Top-Qual ... 2815524590davla wrote:........... you can probably get it cheaper.
However imagine how I feel, I paid about £100 for one about 10 years ago.
