ADS3 & ADS Touring/Rally - What's the Difference?
Posted: Fri Jan 27, 2017 11:03 am
by servetakid
As the title says, is there a difference?
Jordan
Re: ADS3 & ADS Touring/Rally - What's the Difference?
Posted: Fri Jan 27, 2017 12:06 pm
by st0kky
if you ask Martin at Chiselspeed you'll get the best answer
he designed the pipes !!
Posted: Fri Jan 27, 2017 7:27 pm
by camel
The nk rally is sold through AF...the ads 3 is sold through chiselspeed...same manufacturer and similar design...although the nk rally revs further and a good alrounder the ads3 is all out torque with less revs
Posted: Sat Jan 28, 2017 2:57 am
by corrado
I think Chiselspeed have changed the names from ADS3 to Touring / Rally and ADS5 to Race, but as already mentioned best speaking to Chissie direct in case they've changed the pipe's characteristics in any way.
Posted: Mon Jan 30, 2017 10:21 pm
by Adspeed
st0kky wrote:if you ask Martin at Chiselspeed you'll get the best answer
Posted: Thu Feb 02, 2017 12:31 am
by corrado
Adspeed wrote:st0kky wrote:if you ask Martin at Chiselspeed you'll get the best answer
Yes .... but what's the answer to the question? And can you redesign the ADS3 about 5mm thinner at the kickstart side bend, mine touches the cowling bolt with a 3mm base packer?
Posted: Thu Feb 02, 2017 7:40 am
by servetakid
Martin has confirmed that the exhausts are the same. Now im just trying to decide if it is the best for what I want to do.
