Page 1 of 3
Difficulty starting. Ruling out the easy stuff first..
Posted: Wed Jan 25, 2017 12:19 pm
by Snails
Cant get the scooter started. Its never been right/easy since I put a new engine in but it was running before the winter where I did some tinkering with the gearbox. Now it wont start. It sparks and gets fuel so I am a bit stumped. Before I get in to the hard stuff (electrics for me) I want to rule out the carb possibilities
I checked it over. I've even swapped out the main and pilot jets with spares. The starter jet is size 60 rather than the 50 I see recommended on the cambridge lambretta jetting guide. Would that make a difference. I cant seem to find any where selling different starter jet sizes so I guess people dont tend to change them anyway...its phbf 25 mm
Re: Difficulty starting. Ruling out the easy stuff first..
Posted: Wed Jan 25, 2017 2:06 pm
by cgt75b
Hi
Try a 45 pilot jet see if that helps the starting. Also if it's running through an air box take the bellows off the carb and see if it's any easier to start.
I am not saying this will solve your current problem but give it a bash, and see what happens.
Bloody scooters ehh pain in the arse at the best of times : )
The very best of luck with it.
Cgt75b............................
Posted: Wed Jan 25, 2017 2:10 pm
by Snails
Thanks cgt. I have tried removing the air filter and fitting 45 pilot no luck
Posted: Wed Jan 25, 2017 2:33 pm
by cgt75b
Have you tried bump starting it? Only recommended if you know what you are doing, you also need a fair lung capacity to use this technique.
Posted: Wed Jan 25, 2017 3:56 pm
by EddieStone
Easy stuff first: Fit a new plug correctly gapped.
Check the timing - strobe is the best way, with the flywheel powered by a drill.
Check the choke is opening
Check you have compression/no leaks.
I had a poor starting problem with mine which was resolved by making the jetting richer, not leaner. That was after a rebuild though, with a modified kit and a different carb.
In my experience, carbs don't really mess up unless something drastic happens. You could check for blocked jets I suppose, the starter jet in this case. If the plug is wet, then your problems are probably elsewhere.
Poor starting is indicative of a knackered seal.
Posted: Wed Jan 25, 2017 4:20 pm
by Snails
cgt75b wrote:Have you tried bump starting it? Only recommended if you know what you are doing, you also need a fair lung capacity to use this technique.
No i have not. I do know what I'm doing as had a fair amount of experience doing this as a kid.
The reasons why not:
1. It does not even sound like it wants to start
2. Its quite hard work now-a-days
3. Pride
Posted: Wed Jan 25, 2017 4:26 pm
by Snails
EddieStone wrote:Easy stuff first: Fit a new plug correctly gapped.
tried a different plug but will check gap as forgot that when I did it
I've strobe tested it when it was running. Its on my list of tests but as Ive done it already and the scoot has not driven anywhere since I dont see why it should not still be correct - but I will double check if I run out of other ideas
Checked the choke is opening
Comparison seems fine on the kickstart shaft. I dont have gear for compression testing properly. I air tested the engine before I installed it, I've not done so since it started not wanting to start. Again its probably something I might do again if I cant do anything else like the strobing.
Posted: Wed Jan 25, 2017 4:35 pm
by Chris in Margate
Buy a can of Bradex Easy Start from Halfords or similar.
Open throttle and spray generous amount into the carb mouth.
If it doesn't fire or start after 3-4 kicks, then it's not a fuelling issue. If it starts you can discount the electrics. Easy Start will normally start anything.
Compression tester should be used to see if you have at least 100 psi. £10 delivered from ebay.
Air leak derector using bicycle inner tube cut in half and either end secured at inlet and exhaust pipe and then pumped up.
Posted: Wed Jan 25, 2017 5:08 pm
by Snails
Thanks Chris I like the logic of easy start.
Might invest in the compression tester as useful for tuning an stuff - in which I like to dabble
Ive got my home made air leak tester. Its great.
Posted: Wed Jan 25, 2017 5:22 pm
by Snails
Actually thats total claptrap aint it. Thinking of measuring the cylinder head capacity which it wont do. Never mind, I'm sure it will be useful on lots of occasions.
