Rb manifold rubber
Posted: Fri Jan 20, 2017 10:12 am
by maxi
Hi all,
Is anybody else's carb running this close to your engine mounts?
RB20 with step down rubber on Spanish case's. All gaskets fitted correctly.
Re: Rb manifold rubber
Posted: Fri Jan 20, 2017 1:36 pm
by Boreham
Hi, yes exactly as mine as well, when running and the rear shock compresses it does miss (just)
Never had any running issues.
Posted: Fri Jan 20, 2017 2:48 pm
by Knowledge
You could fit a longer con-rod and a packing plate in order to space it off the engine mount, or is that a bit drastic?
Posted: Fri Jan 20, 2017 2:49 pm
by garry inglis
Mine has about 2mm clearance so I ground the bolt down to halfway and got 5mm
Posted: Fri Jan 20, 2017 4:24 pm
by fairspares
My Rb with standard manifold was very close to the large engine mounts, ive now got the LTH manifold fitted and it has a lot more around 8mm clearance.
