Which egt gauge?
Posted: Fri Jan 13, 2017 9:00 pm
by Jonhunter
Hi All
I'm thinking on getting an egt gauge,
Who's using what?
Any feedback would be appreciated
Thanks
Re: Which egt gauge?
Posted: Fri Jan 13, 2017 10:32 pm
by jonashford
Gamma tech
Posted: Sat Jan 14, 2017 2:24 pm
by vegansydney
I'm a fan of the Koso digital. Easy to set up and install, backlit, programmable warning light and affordable.
Posted: Sat Jan 14, 2017 5:24 pm
by Rsport220
Those Koso ones look the same as the Stage 6 I`m using, they`ve worked well for the 1000 or so miles I`ve done. I didn`t bother with the jubilee fixing jobby and welded the sensor boss on the exhaust. But, if I had to chose again I would go for the Gamma tech as I like the idea of all the temperatures, revs, speed in one place and with the use of bar graphs I think it would be easier to spot a problem.
Posted: Sat Jan 14, 2017 10:26 pm
by alanscottj
Stage 6 one I have on has been faultless since fitted a year or so ago (there's the kiss of death!!! Lol )
Posted: Sun Jan 15, 2017 12:20 am
by ducksta
On the Koso gauge what temp would you set as a danger indicator?
Posted: Sun Jan 15, 2017 8:24 am
by kejj
I have this one.
http://www.oopsclunkthud.com/tuning/gauges.pdf
From
http://westach.com
Search for 2DC1-2 for Celsius grade
Quite like it!
Posted: Sun Jan 15, 2017 8:31 am
by Muttley McLadd
I have
this one on my coop.
With
this probe. Weld in bung on the same page.
Tried a Koso one. Lasted less than 1000km before the probe was poked. Replaced that.. and then the unit went too. Weak and feeble.
Buy cheap.. buy twice.
