Page 1 of 2
Trail tech supplier
Posted: Mon Jan 09, 2017 5:15 pm
by chippy
Any one got a trail tech vapor off moorespeedracing. The Lambretta kit seems to have everything included
Re: Trail tech supplier
Posted: Mon Jan 09, 2017 5:43 pm
by garry inglis
my mate got one were just about to fit it during the build a great package
Posted: Mon Jan 09, 2017 9:25 pm
by chippy
You fitting it into headset or toolbox
Posted: Mon Jan 09, 2017 9:55 pm
by garry inglis
Toolbox it's ac so connect to brown from loom
Posted: Mon Jan 09, 2017 10:00 pm
by garry inglis
the stood for the speedo magnet is good and we have used an old bolt on shock mount to attach the pick up
Posted: Mon Jan 09, 2017 11:06 pm
by chippy
Good idea, I've been toying with the idea of getting the ally housing and fitting it into headset, toolbox is one of the nanucci type and there isn't a lot of room. I will be just running the live to the headset as yourself
Posted: Sat Jan 14, 2017 10:30 pm
by alanscottj
Got mine from Moorespeed - fitted in no time at all - has worked perfect since I set it up and speed is spot on. Ended up putting a battery in my oil carrier just to feed the EGT and the Trailtech - much, much brighter and battery lasts months before I have to re-charge. Great bit of kit imho
Posted: Sun Jan 15, 2017 10:01 am
by chippy
alanscottj wrote:Got mine from Moorespeed - fitted in no time at all - has worked perfect since I set it up and speed is spot on. Ended up putting a battery in my oil carrier just to feed the EGT and the Trailtech - much, much brighter and battery lasts months before I have to re-charge. Great bit of kit imho
Thanks for that, I have ordered one off them this week so that is reassuring
Posted: Sun Jan 15, 2017 10:18 am
by chippy
So, alanscottj. You just connected it direct to a spare battery and not to live feed in headset. Just a normal bog standard battery. Thanks
Posted: Sun Jan 15, 2017 10:13 pm
by alanscottj
chippy wrote:So, alanscottj. You just connected it direct to a spare battery and not to live feed in headset. Just a normal bog standard battery. Thanks
Yup - battery from Maplin then put a switch and a fuse in between the battery and the Trailtech and it's been spot on ever since (so long as I remember to switch it off when I put her away!)
