Page 1 of 2
TS1 & VHSH 30
Posted: Sun Jan 08, 2017 8:43 pm
by Boreham
Tried several searches, anyone have a start point for this carb, the needle selection is endless!
TS1 with Franspeed race pipe.
Re: TS1 & VHSH 30
Posted: Sun Jan 08, 2017 9:06 pm
by garry inglis
I've just picked one up on Friday of Ben at rayspeed and as mine is a new build ts230 it's set rich 155 main 48 pilot aq267 and u16 needle 60 choke standard slide
Re: TS1 & VHSH 30
Posted: Sun Jan 08, 2017 11:35 pm
by Boreham
Thanks Gary, can i just confirm the atomiser is a DQ267, the AQ is listed for the smaller PHBL carbs?
Re: TS1 & VHSH 30
Posted: Mon Jan 09, 2017 6:19 am
by garry inglis
Yes dq
Re: TS1 & VHSH 30
Posted: Mon Jan 09, 2017 9:05 am
by garry inglis
Hi just to add the needle on 3rd clip to start then drop to 2nd possibly
Re: TS1 & VHSH 30
Posted: Mon Jan 09, 2017 9:33 am
by Boreham
Cheers Gary, just need to track down a U16 needle.
Re: TS1 & VHSH 30
Posted: Mon Jan 09, 2017 3:49 pm
by Boreham
Boreham wrote:Cheers Gary, just need to track down a U16 needle.
Dellorto UK, £10.34, cheers for the info!
Re: TS1 & VHSH 30
Posted: Mon Jan 09, 2017 5:52 pm
by garry inglis
no probs i have one on my rb200 with franspeed race vertually the same jetting to start but changed to k21 needle 40 pilot 150 main now the k21 is for the 34mm but still fits or you can get away with a k8 if no k21 and a dp267 atomiser
Re: TS1 & VHSH 30
Posted: Wed Jan 11, 2017 9:09 am
by Boreham
Hi Gary,
Did the carb come with the blueprint modification or will you carry this out?
Re: TS1 & VHSH 30
Posted: Wed Jan 11, 2017 10:35 am
by garry inglis
I don't think that's a problem anymore I have just fit mine no problems fastflow tap 300valve I think you had to drill the half round out 2.5mm if I remember iam getting a slight spit back on panels and it goes like you stole it so iam happy with my setup
