1986 T5 rear hub oil seal conundrum
Posted: Tue Jan 03, 2017 5:20 pm
just bought myself a T5 mk1. D plate metallic black, no rot! yeah!
the rear hub was a tad loose. loads of oil and crap in there. could running the loose hub be the cause or is it likely the dreaded rear seal?.
cleaned it up and it looks all good, there's a great big bloody circlip just before the seal/?bearing?. is the T5 an internal oil seal? needing a gearbox out or will it replace from the hub side like an early PX?
is the rear hub specific to the T5 like the front hub?
