Spanish ser 2 mudguard
Posted: Thu Dec 29, 2016 10:53 pm
by Daggs
The rear muddy on my Spanish Li S2 has two large holes (approx 10mm) punched into the rear lower edge. Because they are punched not drilled, I'm assuming they are factory created. Does anyone know why they are there?
Re: Spanish ser 2 mudguard
Posted: Thu Dec 29, 2016 11:06 pm
by whonatic
Daggs wrote:The rear muddy on my Spanish Li S2 has two large holes (approx 10mm) punched into the rear lower edge. Because they are punched not drilled, I'm assuming they are factory created. Does anyone know why they are there?
They're to fit the rubber buffer (square black rubber block) that fits between the mudguard and the frame between the two panel brackets
Posted: Thu Dec 29, 2016 11:15 pm
by Daggs
Cheers whonatic. Fairly obvious when I think about it, doh!
Posted: Thu Dec 29, 2016 11:18 pm
by whonatic
Daggs wrote:Cheers whonatic. Fairly obvious when I think about it, doh!
It's only obvious when you know it :lol:
Posted: Fri Dec 30, 2016 5:17 pm
by charlton_supporter
Any pictures available?
Sent from my SM-N910F using Tapatalk
Posted: Sat Dec 31, 2016 10:02 am
by kevspeed
Available from Scootopia 8-)
Re: RE: Re: Spanish ser 2 mudguard
Posted: Sat Dec 31, 2016 1:59 pm
kevspeed wrote:Image
Thanks for that.
