Gt chain adjuster
Posted: Tue Dec 27, 2016 12:19 pm
by steve chapman
can any one tell me if there has neen an upgrade on the gt pull down chain adjusters,
Ive just tried to fit one and the two threaded sleeves have just snapped as was tightening
Them, i have been told that this has been sorted as it was a weak point
Any help would be great , thanks , Steve
steve chapman
Re: Gt chain adjuster
Posted: Wed Dec 28, 2016 8:39 pm
by Rich_T
Steve, I have sent you a PM regarding your tensioner, can you get in touch please.
Posted: Wed Dec 28, 2016 10:10 pm
by boxofbits
I did the same I over tightened them,they only need to be about 6 8ft pound they don't need to be that tight ,Had mine in now for 2 year now no problems
Posted: Wed Dec 28, 2016 10:38 pm
by Rich_T
The original hex type were 2 ft lbs which is why they were re-designed. The new type with two flat sides will do 6-8 ft/lbs which is correct for standard M6 10mm hex fasteners. If you break the new type then you would also have broken a standard fasteners too or pulled the threads out of the case.
Either way, if you have the hex type get in touch and I'll provide you with the new type.
Posted: Wed Dec 28, 2016 10:45 pm
by boxofbits
Mine are the the hex type sure I did them to 6ft pound seem to be fine
