Vespa PX Steering Lock alternative
Posted: Fri Dec 23, 2016 1:43 am
by GFlint
Hi all,
Dropped forks, looks like the inside of the welded tube damaged allowing barrel to move to a locked position.
.Was wondering, instead of getting a welded steering lock tube done has anyone come up with an alternative ignition that bypasses the steering lock altogether?
Tks
Re: Vespa PX Steering Lock alternative
Posted: Sat Dec 24, 2016 8:50 am
by ducksta
It's only two wires you should be able to put anything in line
Posted: Sat Dec 24, 2016 8:51 am
by ducksta
I did one to a key in frame near autolube just extended the wires.
Posted: Sat Dec 24, 2016 6:19 pm
by GFlint
Mine has 4 wires from the switch PX200E but battery removed. A lot of the wiring has been fiddled with previously.
Thinking about it, would like something different ;)
Sent from my NEO-U1 using Tapatalk
Posted: Mon Dec 26, 2016 7:58 pm
by ducksta
Just work out which 2 are the ignition then find out what the other two are for the ignition barrel turns out of lock then next turn is ignition on so all four wires will either break or make contact just have a play with them in situ
Posted: Wed Apr 12, 2017 5:02 pm
by GFlint
Always nice to show a result, I'd forgotten to post a pic
https://flic.kr/p/TJuq5o
