GP KICKSTART SHAFT
Posted: Sat Dec 17, 2016 3:54 pm
by dazblakey
any recommendations I see lots out there but people grinding them off, any you don't have to grind off
Sent from my D6603 using Tapatalk
Re: GP KICKSTART SHAFT
Posted: Sun Dec 18, 2016 9:24 pm
by dazblakey
Bump
Posted: Sun Dec 18, 2016 9:50 pm
by Knowledge
I'll be honest Daz, I don't understand your post. It lacks punctuation, which might help me.
What's this about grinding? Is this to do with clearance for the top of the clutch?
Posted: Sun Dec 18, 2016 10:27 pm
by dazblakey
Sorry knowledge, I wish to buy a good quality kickstart shaft that doesn't need grinding down to clear the clutch casing
Posted: Sun Dec 18, 2016 10:36 pm
by gaz_powell
I've not gone wrong with genuine SIL but they have all needed a bit grinding to clear.
They are all ground to some extent when purchased, but with so many different clutch assembly variations I think it inevitable that some cleaning up is required.
Steer away from the unknown cheaper ones and use genuine SIL as the base level
Re: RE: Re: GP KICKSTART SHAFT
Posted: Sun Dec 18, 2016 10:37 pm
by dazblakey
gaz_powell wrote:I've not gone wrong with genuine SIL but they have all needed a bit grinding to clear.
Any recommendations for sellers
Posted: Sun Dec 18, 2016 10:50 pm
by HxPaul
The onley place that you can be sure of getting genuine SIL parts is Scooter restorations.
http://www.scooterrestorations.com/lamb ... kickstart/
Posted: Sun Dec 18, 2016 11:08 pm
by dazblakey
Thanks for the replies guys
Posted: Mon Dec 19, 2016 12:13 am
by rosscla
Be careful, as above, SR you know your getting genuine SIL.
eBay is a lottery, I have one which came in SIL (faked) packaging which was all over the place, fitted nowhere.
