GP KICKSTART SHAFT
dazblakey
any recommendations I see lots out there but people grinding them off, any you don't have to grind off
Sent from my D6603 using Tapatalk
dazblakey
Bump
Knowledge
I'll be honest Daz, I don't understand your post. It lacks punctuation, which might help me.
What's this about grinding? Is this to do with clearance for the top of the clutch?
Martin
dazblakey
Sorry knowledge, I wish to buy a good quality kickstart shaft that doesn't need grinding down to clear the clutch casing
gaz_powell
I've not gone wrong with genuine SIL but they have all needed a bit grinding to clear.
They are all ground to some extent when purchased, but with so many different clutch assembly variations I think it inevitable that some cleaning up is required.
Steer away from the unknown cheaper ones and use genuine SIL as the base level
dazblakey
gaz_powell wrote:I've not gone wrong with genuine SIL but they have all needed a bit grinding to clear.
Any recommendations for sellers
HxPaul
The onley place that you can be sure of getting genuine SIL parts is Scooter restorations.
http://www.scooterrestorations.com/lamb ... kickstart/
dazblakey
Thanks for the replies guys
Be careful, as above, SR you know your getting genuine SIL.
eBay is a lottery, I have one which came in SIL (faked) packaging which was all over the place, fitted nowhere.
    Users browsing this forum: Google [Bot] and 7 guests
