sil gp150 not ticking over
Posted: Thu Dec 15, 2016 1:31 am
by mickfeath.
Could anyone help me, my sil gp150 cuts out at low revs.
Re: sil gp150 not ticking over
Posted: Thu Dec 15, 2016 1:41 am
by bazza3004
If otherwise running ok try winding the cable adjuster out on the carb where the throttle cable fits
Posted: Thu Dec 15, 2016 4:25 am
by Ilango
mickfeath. wrote:Could anyone help me, my sil gp150 cuts out at low revs.
Hi Mickfeath,
Need more details to debug the problem. Is this a new build or else it happens off late in a running scooter? Which cylinder setup and carburetor are you using?
There could be more than 1 reason why this should happen.
1. Is the choke cable stuck
2. Do you have to adjust the idle speed screw in the carburetor?
3. Is the air screw open more than what your engine needs?
and many more.
-Ilango
Posted: Thu Dec 15, 2016 10:10 am
by Daggs
If it has previously run O/K? It's most probably a blocked pilot jet.
