Page 1 of 2
DIy cheap thumb choke conversion
Posted: Mon Dec 12, 2016 4:41 pm
by Eibar
Re: DIy cheap thumb choke conversion
Posted: Mon Dec 12, 2016 5:59 pm
by garry inglis
what a great idea what cable did use or have made one up
Posted: Mon Dec 12, 2016 6:12 pm
by Eibar
BSA thumb choke £12.00 ebay . Shimano SIS gear cable inner outer £3 nylon lined with a stainless cable. Cable nipple filed down to fit in choke jet. Small solderless nipple at thumb choke end with a groove cut into chock lever to allow cable adjustment.Its a handlebar type bracket so I binned the lower section and replaced it with a flat bar of alloy.
Total outlay £15.00 and it works a treat with the ability to feed small amounts of choke if needed and it locks out in all postions as tension is set with centre screw. I didnt do this to save money, just to prove it could be done as many have made other great versions before me.
Re: DIY cheap thumb choke conversion
Posted: Mon Dec 12, 2016 6:45 pm
by Knowledge
Neat.
BTW, if you have to solder your own nipple on, then a mild-steel cable is better than stainless. If in doubt, test the cable with a magnet.
Posted: Mon Dec 12, 2016 6:49 pm
by Eibar
and fzr600 is a crackin version martin
Posted: Mon Dec 12, 2016 8:29 pm
by jason frost
I use the gear change off a push bike , they have a few clicks on them so you can just open it a bit at a time and leave it
Posted: Mon Dec 12, 2016 9:03 pm
by garry inglis
whats the mount on top off the hydraulic bowl is it a rev counter
Posted: Mon Dec 12, 2016 10:16 pm
by Knowledge
Eibar wrote:and fzr600 is a crackin version martin
For those that haven't seen this, here is a photo.
Posted: Tue Dec 13, 2016 9:17 am
by Eibar
garry inglis wrote:whats the mount on top off the hydraulic bowl is it a rev counter
yeah sendec rev counter and a little mounting block that fits to master cylinder with grub screws
Posted: Tue Dec 13, 2016 9:24 am
by garry inglis
Eibar can you by them or have you made it because I'd be very interested
