Gear bix question
Posted: Mon Dec 12, 2016 1:07 pm
Hi
Had to strip my gearbox and reassemble - once assembled its not that easy to turn by using the spider. I can turn it by hand but its not that easy. Using a socket drive it is fine.
Should I be worried, is there anything I can do?
Its not the big shim clearance causing the issue. The engine is in the scoot so its not on a bench or anything, not that I really think that makes any difference as its not in gear.
