Page 1 of 6
TS1 225 Kits - advice please
Posted: Sat Dec 10, 2016 12:26 pm
by Strummer10
Guys........with the TS1 225 kits
1/ what is the significance of using the new AF cylinder head 9.5.1 ? Does this increase compression or the opposite ?
2/ Would a BGM clubman version 3 work ok with the above kit of hinder performance.
I'm thinking of running it on a standard Italian GP 200 gearbox and sprocket set up, but should this also be changed. Was thinking a hybrid between a touring set up and around town
Re: TS1 225 Kits - advice please
Posted: Sat Dec 10, 2016 1:26 pm
by drunkmunkey6969
Strummer10 wrote:Guys........with the TS1 225 kits
1) The 9.5:1 head will increase compression if you currently have an 8.5:1 head, or decrease compression if you have a 10.5:1 head.
2) Yes it would work OK, it would increase performance compared to an AF Clubman, or decrease performance compared to a decent touring expansion chamber.
All things are relative.
Posted: Sat Dec 10, 2016 3:26 pm
by Strummer10
Cheers.......no head yet as kick being considered for purchase. Would like an expansion pipe tbh but want to retain standard looks, considering a clubman type exhaust what's the best out there would you say for the set up i'm after ?
Posted: Sat Dec 10, 2016 3:46 pm
by soosh
A few recommend the bgm clubman and have had good results. I don't know anyone who has used a Gori with a TS but I've got one on my iron barrel and it's fantastic.im using a JL3 curly on my TS which tucks away quite tidy and that's a great pipe.
Posted: Sat Dec 10, 2016 4:56 pm
by Padge
As Dan and others have has said on here in other threads, a good clubman will be better than a cheap s**t expansion, a good expansion p****s all over a good clubman....and they sound better !!
Posted: Mon Dec 12, 2016 8:10 pm
by Strummer10
Yes agreed a clubman won't meet the same as an expansion, but I was thinking of keeping it standard looks
Posted: Tue Dec 13, 2016 11:11 pm
by corrado
Backing up what Dan says. AF used to offer 2 heads one was 8.5 to 1 compression and they also did a skimmed version of this that was 9.5 to 1. They recommend the 9.5 version for the TS1 & RB.
Posted: Sat Dec 17, 2016 10:00 am
by Strummer10
Cheers for the reply. Next question is there any difference in fitting a crank with a longer stroke.....'real benefits' over the standard stroke crank ?
Posted: Sat Dec 17, 2016 10:31 am
by Minority
Longer stroke or longer conrod?
Longer stroke = more cc (e.g. your 225cc would become a 230cc using a 60mm stroke)
Longer conrod = smoother engine (and easier to play with packers/gaskets to get the port timings you want)
Posted: Sat Dec 17, 2016 5:28 pm
by Strummer10
Cheers Minority................I guess it would be beneficial to have both ? therefore on a TS1 what would be optimium would it be a 115 conrod ? and can you recommend who does a crank that would fit the bill ? cheers
