Hole appeared in casing via stator plate bolt!!!!
alanscottj
Decided to give my engine a once over while having some work done on cylinder. Whilst cleaning inside the crank case mouth I noticed a little hole. Figured the direction it was coming from was stator side so took one of the bolts off the stator plate and Sure enough a hole goes right through! ImageImageImage
