vespa rally 180 crank quetion
smoore-gt225
Main scooter: lambretta GT200
i have a rally 180 which is on 6v points, is it right that a p2 crank flywheel and stator fit in if you grind off the lip on the crank
hopefully that makes sense just want to make it more reliable
cheers steve
Yes. You need to take a bit off the stator too, to go over the bearing.
