T5 seizure crank ok?
Posted: Mon Dec 05, 2016 9:56 pm
My lads T5 classic has just seized up coming home from work. The autolube pipe had come off :shock
Ive taken the barrel off and the barrel and piston are knackered, all the plating has scored off by the exhaust port. The rings haven't broken but stuck in the grooves on the side of the seizure. Nothing appears to have come off and gone down into the bottom end.
My question is what is the chance of the crank being ok? Is there anyway i can check it without totally striping the engine?
Cheers john..
Cheers john..
