200 cases or Small block casing machining ????
225worb
Main scooter: Vespa 225, Falc , 230 S2
Ive just purchased an old skool cast iron Kegra tuned 225 cylinder (wosner piston) and 60/110 crank for an old skool repalacement build for my s2 heap Im looking for 200 cases ! Now i realise that the prices vary thats if i can actually get one ..
Which are the stronger cases firstly or are they much the same??
Or would i be better to use a smallblock and have them machined to 200 cylinder stud/spigot spacings and what price should i expect to pay ...Oiltek look the nuts with regards to carring out the work...
Thanks...
Scooterdude
I've recently had my engine done and was thinking 200 cases or have the existing small block altered to suit, contacted MB and was quoted £380 (what a joke!) I told him I'd be better off buying a new 200 case to which he replied yes if you can find one, well Rayspeed have them for £340 Harry Barlow has them for the same so it's a no brainier really.
garry inglis
ive just got mine done at oiltech £180 to have the case done and £12 to put a1mm trench in for a 60 crank plus post back £12 it took 7 weeks to get done what he does is wait till he gets 8 cases and then does that batch if you phone they will tell you how many they have and you might be lucky and be no8 and get done next week but quality job he even did the mag housing face just to tidy it up
Scooterdude
Big difference between £180 and £380, robbing b@5t@rd. I never persued it with anyone else as I thought that was the going rate, remind me not to deal with them again!
gaz_powell
Plus one Oiltek - Pauls a good bloke.
Plenty of 150 casings (although they are getting more expensive) - I used an immaculate early SIL one I had in the garage, so I ended up with a great 200 casing for less than half the price of a new Indian 200.
I'm looking forward to the UNI casing coming out.
225worb
Thanks guys
Totally agree Scooterdude......takes the p155 and the clowns still get away with it !!!
Shop around ......
Scooterdude
Just been looking for a stator wire retaining clip 31p from one supplier £6.95 from you know who, feckin rediculous!
    Users browsing this forum: No registered users and 83 guests
