Grinding Bits
Posted: Thu Nov 17, 2016 3:58 am
by Lamaddict
Looking to buy some but which ones? I'm planning to take off the sharp edges around the ports.
Re: Grinding Bits
Posted: Fri Nov 18, 2016 3:14 pm
by 10 inch Terror
These are very good for the money.
https://www.ebay.co.uk/itm/221795028249
Re: Grinding Bits
Posted: Fri Nov 18, 2016 3:28 pm
by fairspares
It might be worth using demel type small sanding drums , you will be less likely to take to much off or slip and cause damage if this is your first attempt at this, if you planning on taking quite a bit off then the burr cutters will be better.
Re: Grinding Bits
Posted: Fri Nov 18, 2016 3:32 pm
by EddieStone
How about a file? A small half round file should sort it
Re: Grinding Bits
Posted: Fri Nov 18, 2016 4:09 pm
by 10 inch Terror
I use them with an air grinder. If you're careful they can be used on the casing transfers and are particularly good on cast iron barrels,you just need a steady hand. The dremel can be used to finish off and polishing up.
Re: Grinding Bits
Posted: Sat Nov 19, 2016 12:08 am
by corrado
EddieStone wrote:How about a file? A small half round file should sort it
That's all I use to chamfer the ports, you can just about get to all of them if you're careful.
Here's a link to proper porting tools. http://www.ccspecialtytool.com/
Here's a video of the proper tools in use .. https://www.youtube.com/watch?v=43Qb8tJ49A8
Re: Grinding Bits
Posted: Sat Nov 19, 2016 3:30 pm
by EddieStone
Things go wrong much more slowly with a file!
Re: Grinding Bits
Posted: Fri Nov 25, 2016 2:12 pm
by corrado
EddieStone wrote:Things go wrong much more slowly with a file!
Amen to that. :lol:
Re: Grinding Bits
Posted: Fri Nov 25, 2016 5:26 pm
by Chris in Margate
What a brilliant saying.
"Things go wrong much more slowly with a file!"
Love it. So true.
Re: Grinding Bits
Posted: Mon Nov 28, 2016 11:39 pm
by corrado
I tried one of those 3 legged glaze busters in a hand held electric drill once. Just a practice run on an old knackered barrel, now that did quickly get out of hand, it caught the sleeve of my sweatshirt and got jammed. I had visions of it ripping a chunk out of my arm, but thankfully it jammed in the material when it wrenched the drill out of my hands. I leave that job to an expert these days and binned the glaze buster.
