Drive side bearing
whonatic
I'm having trouble getting the above to seal on a 225 avanti.
I've used 2 different bearings both with the extra seal in, but still burning oil. I've never had this much trouble with the bearings with no seal in - are these just a fad or do I just revert to the bearing with no seal in?
I've also tried MB viton and Rolf seal - still burning gearbox oil.
Using an innocenti seal plate, flat and perfectly round
Any advice greatly appreciated
garry inglis
How are you fitting the crank and had the two previous seals have tears or splits in and have you tried different halite gasket
garry inglis
You need to make sure the halite washer is being compressed by the seal plate.
fairspares
rosscla wrote:You need to make sure the halite washer is being compressed by the seal plate.
yes very important , you will find the gaskets come in various thicknesses from 0.5mm up to 1mm , im just rebuilding a couple of spanish engines and they will only seal with 1mm hallite using the original plates , with some remade plates thinner gaskets can be used .
whonatic
garry inglis wrote:How are you fitting the crank and had the two previous seals have tears or splits in and have you tried different halite gasket
Pull the crank in slowly , stopping and turning crank every few mm. crank and seal oiled to ease passage
whonatic
Where do I get 1mm ones from ?
whonatic
Ok good advice cheers 8-)
fairspares
i get mine from af rayspeed and mrb , i use skf bearings with extra seal and now put a smear of yamabond on the gasket after someone on here suggested doing it in a previous thread about drive side sealing , it seems to work very well , but dry build first to make sure the drive plate is touching the gasket , it will usually show some markings on the gasket, i start by trying thinner gaskets first, the only problem using thicker gaskets is that sometimes there is not enough clearance between the crank and drive-plate so a crank shim is needed again available from af or mrb.
Scooterdude
Sounds like. Your messing up your oil seal when fitting the crank (as I was before Mr Barlow showed me how to do it correctly) put plenty of grease around the seal and the crank and draw it through SLOWLY! Twisting the crank every few twists of the nut.
I use two 1mm halite seals sealed together with a smear of grease and double lip oil seals both from Harry Barlow (the Leicester one). No more problems...
    Users browsing this forum: Google [Bot] and 22 guests
