Page 1 of 2
Gt 186 kit info
Posted: Sat Nov 12, 2016 6:52 pm
by brucie
Looking to build a set up as per the touring spec on the get manual. Wondering what speeds this will give for cruising and top end. Going to use the 25 dellorto or is it worth going up to a 30. Have been looking at the scootopia clubman or is there a clubman style exhaust that would be better.
Cheers bruce
Re: Gt 186 kit info
Posted: Sat Nov 12, 2016 7:06 pm
by Donnie
Personally I wouldnt bother with the 25mm, would go for 28 or 30 as there's more knowledge for setting up etc as well as parts and jets for them.
Also, good idea going for a clubman type exhaust Id say, definitely if I manage to get mine fixed
I'd never use an expansion again
Re: Gt 186 kit info
Posted: Sat Nov 12, 2016 8:09 pm
by Scooterdude
I'm no expert but wonder as your kit has a reed valve would it be worth looking at a Mikuni tmx27 just something slightly different to think about.
Scootopia clubmans are brilliant by the way.
Re: Gt 186 kit info
Posted: Sun Nov 13, 2016 9:01 am
by wrecklessrobbie
Ask Eden or Rich Taylor on this site.
they make and sell them.
they will tell you the perfect set up.
look at some of Edens videos. Very impressive results.
Re: Gt 186 kit info
Posted: Sun Nov 13, 2016 9:44 am
by hendy
I agree with Dornie.
Mine is running with a phbh30 through marchald filter, 58/107 crank, bgm clubman. My gearing is around 5.0. Fixed ignition. Matched cases to transfers and raised exhaust slightly.
Only around 14bhp but lovely to ride.
Initially I had phbl25 through airbox and ancillotti. It was under 10bhp and painful to ride.
Re: Gt 186 kit info
Posted: Sun Nov 13, 2016 10:12 am
by mark-b
Henry, what sort of mpg are you getting with your set up please?
Thanks, Mark
Re: Gt 186 kit info
Posted: Sun Nov 13, 2016 10:32 am
by mark-b
mark-b wrote:Henry, what sort of mpg are you getting with your set up please?
Thanks, Mark
Sorry Hendy / Henry.... a combination of predictive text and sausage fingers
Re: Gt 186 kit info
Posted: Sun Nov 13, 2016 12:12 pm
by hendy
No idea what mpg I get but VERY broadly I put 20 quid in to go from Newcastle to breighton ferry and back.
Re: Gt 186 kit info
Posted: Sun Nov 13, 2016 12:59 pm
by mark-b
Cheers Hendy
Re: Gt 186 kit info
Posted: Sun Nov 13, 2016 10:50 pm
by gerryjunior
whats cruising speed on these kits with a clubman type exhaust. in a series 2 ?
