tv 175
Posted: Sun Nov 06, 2016 8:41 pm
by lammy666
evening lads, my m8 has a tv175 s3 with a gp crank, 12volt conversion and a mugello kit fitted.
would a standard 175 top end fit straight on or would the length of the conrod be a huge problem.
Re: tv 175
Posted: Sun Nov 06, 2016 8:57 pm
by garry inglis
The TV had a116 special crank originally and a175 only needs a58x107 crank what gp crank is in
Re: tv 175
Posted: Sun Nov 06, 2016 9:10 pm
by lammy666
think its a gp 200 crank 107 mm.
i imagine that this wont be suitable with a standard tv175 barell
Re: tv 175
Posted: Sun Nov 06, 2016 9:42 pm
by bristolmod
it will be fine BUT you will need a "normal" piston (i.e. one with the gudgeon pin at the same height as an LI; SX and NOT the higher pin as per the proper TV175 piston)
Re: tv 175
Posted: Sun Nov 06, 2016 9:59 pm
by lammy666
cheers for that guys
