Dyno
Posted: Sat Nov 05, 2016 4:38 pm
by ricardo59
Hi all
just had a new Polini 177 kit fitted and was advised to run in for 500km only using 3/4 throttle and to get it Dynoed, my question is do i do the 500km before i have it dynoed?
Re: Dino
Posted: Mon Nov 07, 2016 8:06 pm
by gaz_powell
You should have it ran in before the dyno work or have the bore/piston clearance adjusted accordingly if short of running in time.
Check with the kit instruction but 500km doesn't seem much.
Re: Dino
Posted: Mon Nov 07, 2016 9:23 pm
by garry inglis
If you have the jetting set right ok to run in but if it's running lean you could seaze it up I would get it dynoed to check and they will set it a tad rich for running in
Re: Dino
Posted: Mon Nov 07, 2016 11:07 pm
by ricardo59
My mechanic has set up the carb for me, he has jetted it to run rich untill it is run in
Re: Dino
Posted: Tue Nov 08, 2016 5:50 pm
by gaz_powell
As Mr punch says that's the way to do it.....
