kickstart issues destroyed the casing
Posted: Sat Nov 05, 2016 12:02 pm
I have just finished meticulously building myself a monster malossi MHR 221 engine. It really was an exercise in OCD I built the whole engine with the best bits available and spent ages tuning, porting, pre jetting the carb, and setting the ignition timing before fitting it into the frame and starting it up. When first started I noticed there was a lot of noise coming from the bearings especially when the clutch was pulled in but put this down to oil circulation and the bearings being brand new. Eventually it quietend down and I felt confident taking it out for the first time, it performed well and I tried to keep the revs and speed down.
After a couple of kilometers I returned home to adjust the clutch and gear selector, so far so good. I fired it up again and it sounded well so I gave it some revs as I pulled away and instantly became away of a violent bumping under my butt. I stopped as quick as I could and realized that the kick start had dropped and hit the road forcing the quadrant to smash through the outer engine casing leaving a trail of engine oil along the road. Ever seen a grown man cry ??
I pushed it back to my garage and after drying my tears tore it down to see what had happened and the reason behind it. On closer inspection I found the kick start gear had seized to the end of the Christmas tree, whether this could be responsible for the kickstart dropping (or being forced down through the casing) and hitting the road I am not sure, I haven't ever heard of this before and neither have any of my mates. It was a perfect fit when I originally fitted it onto the end of the Christmas tree shaft.
I have researched the subject as best I can and read about the problem kickstart dropping at high revs and am now wondering if the 2 issues are related or not. Has anyone else ever suffered this problem (either one) are they related ?? Why did it happen ?? And most importantly how did you rectify it ?? My engine casing is coming back from welding next week and I want to ensure this doesn't happen again on a side note al the parts used (casing rubber buffers, kickstart quadrant, kickstart gear, kickstart gear spring, main kickstart spring, and all associated parts seals bearings etc.) are all brand new and built into a NOS PX200 casing.
Any ideas ?? Thanks in advance.
