Drive side plate
Posted: Fri Nov 04, 2016 11:49 pm
by onefortheroad
What's the difference between the non grooved drive side oil plate
https://www.ebay.co.uk/itm/121467221573
And the grooved one
https://www.ebay.co.uk/itm/111259770654
And which one do I need for an Li3 casing with a gp crank?
Re: Drive side plate
Posted: Sat Nov 05, 2016 12:05 am
by Grumpy225
Technically speaking you will gain a hair more case volume by using the grooved one. In reality though I doubt it makes any difference at all. If it helps, the solid type is a later more modern design (dl/GP style).
I tend to use the grooved Italian ones in my builds since the alloy solid type always seemed to be warped.
Posted: Sat Nov 05, 2016 12:07 am
by onefortheroad
So any will fit?
Posted: Sat Nov 05, 2016 1:09 am
by rosscla
Broadly, but check the plate is centred - try it in all four positions.
Posted: Sat Nov 05, 2016 8:15 am
by Scooterdude
And make sure your Helite seal isn't to thick that it forces the drive plate against the side of the crank, I've recently had a couple from Beedspeed that apart from being to thick were cut on the p155. I now use two of the thin ones from Harry Barlow paired up...spot on..
