Page 1 of 2
BGM V3 Stator Low Readings.
Posted: Fri Nov 04, 2016 9:29 am
by Scooterdude
Ok more so out of curiosity really than any other reason and while the rest of my engine is with Harry I decided to do the stator plate test as per the Stickys manual. White to red=65 instead of the recommended 95-120 ohm. White to green=318 rather than the recommended 450-540 ohm.
Is it time to start worrying?
And without wanting to spend on the cassatronic system or the Aprilia conversion just at the moment what would be regarded as a better or indeed the best stator plate? AF, latest version BGM, eBay special etc etc?
I'm pretty handy with a soldering iron so don't mind fitting new coils/pickup to the one I have but don't want to spend on BGM parts if they only last this long (10 months) did someone say Vespa parts are better? And will fit?
Re: BGM V3 Stator Low Readings.
Posted: Fri Nov 04, 2016 11:01 am
by Lambretta Sash
Id check red and green to stator plate 1st and components to see if wire has break or earth tag loose. if all fails go vespa parts or go for the ve stator which seems to be alot better than most on market from my experience.
Posted: Fri Nov 04, 2016 11:08 am
by Scooterdude
Thanks for the reply but what are the specific Vespa parts I need? Also what's a VE stator? (Sorry I've only been into scooters a few months)
Posted: Fri Nov 04, 2016 11:58 am
by HxPaul
Posted: Fri Nov 04, 2016 12:38 pm
by coaster
Anton Tambs on Face Book will re-furb your stator to better than new, the guy is an electronic genius and id on the brink of launching a new ignition for lambrettas with the pick-up on the outside and also possibly with a 3 phase option using the original flywheel. I'm VERY interested in this myself
I think he also makes the Gamma Tech Speedo/rev counter/CHT gauge.
Posted: Fri Nov 04, 2016 12:56 pm
by Scooterdude
Cheers for that Paul and Coaster that's very interesting will check it out, thanks.
Posted: Fri Nov 04, 2016 2:11 pm
by coaster
Scooterdude wrote:Cheers for that Paul and Coaster that's very interesting will check it out, thanks.
That's Anthony Tambs btw
Posted: Fri Nov 04, 2016 2:57 pm
by gaz_powell
what happened to the Uni 120W stator that appeared for a short while for around 60 quid ???
Posted: Sun Nov 06, 2016 9:55 pm
by Bilko
coaster wrote:Anton Tambs on Face Book will re-furb your stator to better than new, the guy is an electronic genius and id on the brink of launching a new ignition for lambrettas with the pick-up on the outside and also possibly with a 3 phase option using the original flywheel. I'm VERY interested in this myself
The ignition is really exciting news. I'm looking forward to this.
He's just put up his stator plate refurb procedure on FB with photos and it's a work of art.
Yes, he does the speedo's. I've just installed one and it's superb.
Posted: Sun Nov 06, 2016 11:10 pm
by vega125s
Hey could someone post up the Facebook info as I'm not on it , all sounds interesting .
