Homemade DC wiring Loom
Posted: Sat Oct 29, 2016 5:24 pm
by diesel
Could any of the electrical gurus tell me the gauge of cable required to manufacture a loom. Is 25amp 2mm sq thin wall insufficient, overkill or just right. Would different functions require different gauges? i.e battery feed versus pilot light. I realise that needing to ask something as basic as this may lead to calls of " if you don't know that don't try making a loom" but indulge me please.
I thank you in advance.
Re: Homemade DC wiring Loom
Posted: Sat Oct 29, 2016 5:32 pm
by DigDug
http://www.vehicle-wiring-products.eu/s ... a3016fcbf7
I use the thin-wire multicore for my wiring. So much easier to use.
Posted: Sat Oct 29, 2016 5:39 pm
by diesel
Yes but what Gauge or amp rating do you use DigDug?
Posted: Sat Oct 29, 2016 5:54 pm
by HxPaul
diesel wrote:Could any of the electrical gurus tell me the gauge of cable required to manufacture a loom. Is 25amp 2mm sq thin wall insufficient, overkill or just right. Would different functions require different gauges? i.e battery feed versus pilot light. I realise that needing to ask something as basic as this may lead to calls of " if you don't know that don't try making a loom" but indulge me please.
If you dont want this company to make you a wiring loom,you can give them a call and ask what gauge of cable is the best to use.
http://www.ebay.co.uk/itm/12V-Lambretta ... SwShJXL5nq
Posted: Sat Oct 29, 2016 6:35 pm
by Morgan
1.00mm will be fine. As said the stranded is easier to work with (more strands the better) and stranded also carries more current than solid.
Posted: Sun Oct 30, 2016 7:14 pm
by EddieStone
Does anyone know where you can buy the same gauge and colours used in a Lambretta loom? I need to make a loom for my chopper and having the rift gauge and colours would be useful
Posted: Sun Oct 30, 2016 8:30 pm
by dennis
Just buy a caravan cable off of ebay,about £2 a metre all the colours are in the cable plus extra colours,i used the whole cable as a loom,got extra lights on my scoot.
Posted: Tue Nov 01, 2016 10:59 pm
by diesel
Thanks lads
Posted: Wed Nov 02, 2016 11:24 am
by EddieStone
Thanks, I bought a 5m 7-core cable for trailer/caravans off eBay for about £7 delivered. Should be more than enough!
