Page 1 of 3
Trail Tech Vapor ----- Any good?
Posted: Wed Oct 19, 2016 7:18 pm
by alanscottj
Had my SIP speedo for 3 years now and I think it is time for a change - thinking of getting one of the TrailTech Vapor ones - before I jump straight in I thought i would see what you guys think of them. Any issues I should be aware of? Will they run ok with Varitronic?
Many thanks in advance
Re: Trail Tech Vapor ----- Any good?
Posted: Wed Oct 19, 2016 9:37 pm
by bazza3004
Hi cant answer your question reggarding varitronic but i have a vapor and while im still finishing thescoot i have the vapor up and running. Its easy to wire up and prob has more functions than i need tbh. I have a non battery gp so took me feed from the horn live. The set up instructions are easy to follow also.
Posted: Wed Oct 19, 2016 9:53 pm
by jonashford
I had one it was good, but changed for the gamma tech which is far superior
Posted: Wed Oct 19, 2016 10:21 pm
by alanscottj
jonashford wrote:I had one it was good, but changed for the gamma tech which is far superior
Yes, I have had a look at them too - but the one would need is a little pricey
by alanscottj
bazza3004 wrote:Hi cant answer your question reggarding varitronic but i have a vapor and while im still finishing thescoot i have the vapor up and running. Its easy to wire up and prob has more functions than i need tbh. I have a non battery gp so took me feed from the horn live. The set up instructions are easy to follow also.
Have you run it on the road yet?
Posted: Thu Oct 20, 2016 6:17 am
by Toddy
+1
Posted: Thu Oct 20, 2016 7:47 am
by jonashford
alanscottj wrote:jonashford wrote:I had one it was good, but changed for the gamma tech which is far superior
Quality stuff does cost
Posted: Thu Oct 20, 2016 10:32 am
by alanscottj
jonashford wrote:alanscottj wrote:jonashford wrote:I had one it was good, but changed for the gamma tech which is far superior
I do agree - I wish I could afford the RTSE but I'm sure the Vapor will do for now
Posted: Thu Oct 20, 2016 6:29 pm
by Hammy
Ive had a trail tech for 5 or 6 years now , changed the battery in the back of it 3 times , great bit of kit does everything i need .
Posted: Thu Oct 20, 2016 8:48 pm
by bazza3004
alanscottj wrote:bazza3004 wrote:Hi cant answer your question reggarding varitronic but i have a vapor and while im still finishing thescoot i have the vapor up and running. Its easy to wire up and prob has more functions than i need tbh. I have a non battery gp so took me feed from the horn live. The set up instructions are easy to follow also.
Only for short distances to check it worked
