Scoot RS pipe
Posted: Fri Oct 14, 2016 11:24 pm
by Scooterdude
Just bought one just for the heck of it really as it was so cheap. So any good? What's the characteristics of these pipes, do they make good power? Cheers guys.
Re: Scoot RS pipe
Posted: Sat Oct 15, 2016 9:09 am
by kejj
had one for years, resembled the pm pipe. think it liked gp gearing but had troubles reaching revs for 4th gear!
Re: Scoot RS pipe
Posted: Sat Oct 15, 2016 10:34 am
by rosscla
Yes, it's a alleged to be copy of the PM25 - quite a revvy pipe so would like short gearing
Re: Scoot RS pipe
Posted: Sat Oct 15, 2016 1:29 pm
by shocky
Got one on my stg4 200 pulls top from 30 mph all the way to 67 GPS I've tried lots of other pipes jl2 jl3 jl4 scoot rs pulled better and lower than all of them I've got a pm25 as well same characteristics but louder
Re: Scoot RS pipe
Posted: Sat Oct 15, 2016 2:03 pm
by Scooterdude
Wow so all in all then a pretty good pipe! And without the ground clearance issues of the JL series.
Re: Scoot RS pipe
Posted: Sat Oct 15, 2016 4:25 pm
by kejj
I think so, sold mine off and gone with clubman, the scoot is faster when I can reach forth gear
Overall I've noticed that the scootrs pipe lasted longer than the sterling version of the said pipe(mate had a sterling).
Re: Scoot RS pipe
Posted: Sat Oct 15, 2016 5:46 pm
by soosh
If it is a copy of the PM then it's a good pipe. Depends on your motor spec but I had one on my ported SIL barrel with a 28phbh. Pulled 4.8 even 2 up.
Re: Scoot RS pipe
Posted: Sat Oct 15, 2016 7:37 pm
by Scooterdude
Haha Soosh, just watched that YouTube video at the bottom of your page, nearly fell over laughing...brilliant!
Re: Scoot RS pipe
Posted: Sat Oct 15, 2016 9:55 pm
by soosh
Ha, Forgot about that.
Yes...,be aware.
Re: Scoot RS pipe
Posted: Sun Oct 16, 2016 10:28 am
by Chris in Margate
I've had one fitted for years. Good pipe. Downside for me is access to the flywheel side manifold nut. You need a good open ended spanner on it. Ring spanner won't fit. I bought an expensive 11mm and shortened the "jaws" on it. I also have abut 5 other spanners at slightly different angles to move it on 1/16th of a turn at a time !
