RT225 25 Dellorto Clubman?
Lamaddict
Thinking about this set up. Anyone running one the same or similar?
Timbo
I ran one on a 26 delly but changed to a 28 and get a much better performance. BGM clubman as well.
Timbo
Mark ULC
Main scooter: LI Series 2
I run this but with an NK road/rally pipe. Runs well, economical when not thrashed. The pipe gives good torque, max bhp and torque at 6200rpm, runs out at 7000rpm so 25 mm dellorto enough for this. If I put a bgm clubman on I would go to a bigger carb to feed higher rpm. Be interest to know how much better a 30mm is than a 28mm for an out of the box RT kit.
