RE-USE or bin bearings.........
Posted: Tue Oct 11, 2016 11:48 am
If I have a seal issue or problem where the crank has to come out after a few miles it Seems a bit of a waste to keep throwing driveside bearings in the bin!!!!If I push out a crank from the drive side bearing I normally renew the bearing due to the pressure used to push it out.......sometimes the bearings spin as good as the new replacement ( there is others removed which are obviously damaged or worn)
SO DOES ANYBODY REMOVE AND REPLACE CRANKS ON THE SAME BEARING TO NO ILL EFFECT????????
or is it a fools gold
