TS1 200 carb advice needed
Posted: Mon Oct 10, 2016 12:46 am
I've recently put together a TS1 200, it's fitted with a bgm v3 clubman. The carb set up I've currently got is a PHBH 28mm open mouthed
Main 128
Pilot 52
Atomiser av266
Needle x7 second clip
The air screw is 2 turns out
If anyone has a similar set up I'd be most interested in what carb you have. At the moment mine is pretty unresponsive until about half throttle or until it's running on the main jet. I'm not adverse to a carb change its just what I happened to have so I put it on.
Any help gladly appreciated
Main 128
Pilot 52
Atomiser av266
