Small end bearing
kevspeed
Anybody know if there is a small end roller bearing available to suit a 15mm gudgeon pin conversion?
Reason being,I've just dug out an old Kawasaki 150 kit with the KH 400 piston,and fancy giving it a go 8-)
hendy
You also need to think about width.
What size gap does it need to fill in the piston?
kevspeed
hendy wrote:You also need to think about width.
19mm-20mm,i have a feller that can make me shims to suit 8-)
    Users browsing this forum: Google [Bot], Semrush [Bot] and 1 guest
