alter gp case
garry inglis
is it possible to dremmel off the lug inside the case were the brass clutch bush goes and then use the case for an li150 caseing and clutch :?:
garry inglis
by the way this server is not working right it just said unsucesfull post then you do it again and two go up
garry inglis wrote:by the way this server is not working right it just said unsucesfull post then you do it again and two go up
Yes, looking into it. Cheers
HxPaul
garry inglis wrote:is it possible to dremmel off the lug inside the case were the brass clutch bush goes and then use the case for an li150 caseing and clutch :?:
I'm sure you dont have to cut the lug off,just remove the brass bush.
DaveTomo
Main scooter: SX 200
"I'm sure you dont have to cut the lug off,just remove the brass bush."
+1
Timbo
I believe this is quite a common thing to do and helps the clutch. It's been done on mine.
garry inglis
ive just took my li casing off and looking at were the li clutch small lever sits to the left it would catch on casting but i will just have to wait till the gp casing turns up and i will see whats to do
DigDug
What not just swap out the LI pressure plate for a GP one? :idea:
Did you have to do that?
another consideration is the kickstart ramp /end plate !
    Users browsing this forum: Baidu [Spider] and 9 guests
