alter gp case
Posted: Sat Oct 08, 2016 6:35 pm
by garry inglis
is it possible to dremmel off the lug inside the case were the brass clutch bush goes and then use the case for an li150 caseing and clutch :?:
Re: alter gp case
Posted: Sat Oct 08, 2016 6:38 pm
by garry inglis
by the way this server is not working right it just said unsucesfull post then you do it again and two go up
Re: alter gp case
Posted: Sat Oct 08, 2016 6:48 pm
by drunkmunkey6969
garry inglis wrote:by the way this server is not working right it just said unsucesfull post then you do it again and two go up
Yes, looking into it. Cheers
Re: alter gp case
Posted: Sat Oct 08, 2016 7:27 pm
by HxPaul
garry inglis wrote:is it possible to dremmel off the lug inside the case were the brass clutch bush goes and then use the case for an li150 caseing and clutch :?:
I'm sure you dont have to cut the lug off,just remove the brass bush.
Re: alter gp case
Posted: Sat Oct 08, 2016 7:40 pm
by DaveTomo
"I'm sure you dont have to cut the lug off,just remove the brass bush."
+1
Re: alter gp case
Posted: Sun Oct 09, 2016 9:35 am
by Timbo
I believe this is quite a common thing to do and helps the clutch. It's been done on mine.
Re: alter gp case
Posted: Sun Oct 09, 2016 12:20 pm
by garry inglis
ive just took my li casing off and looking at were the li clutch small lever sits to the left it would catch on casting but i will just have to wait till the gp casing turns up and i will see whats to do
Re: alter gp case
Posted: Sun Oct 09, 2016 2:54 pm
by DigDug
What not just swap out the LI pressure plate for a GP one? :idea:
Re: alter gp case
Posted: Sun Oct 09, 2016 3:09 pm
by sean brady scooters
another consideration is the kickstart ramp /end plate !
