MBD strengthened ( lightened ) clutch crown wheel
Posted: Thu Oct 06, 2016 1:51 pm
by watto66
Hello All ,
I need a stronger clutch centre spider to fit my Rapido 250 motor it will be going into a MB Developments crown wheel probally with a readspeed 5 plate clutch . I know the obvious would be to purchase the MB clutch spider but I can't quite stretch to it money wise at the moment can anybody suggest an alternative ? Motors spec is nothing radical Rapido 250 , BGM pipe ! BGM Stator and flywheel , 30mm dellerto with LTH reed valve .
Many thanks
Re: MBD strengthened ( lightened ) clutch crown wheel
Posted: Thu Oct 06, 2016 11:04 pm
by Doom Patrol
I was looking at a Scootopia one at the weekend. They looked good. Worth checking out?
Posted: Thu Oct 06, 2016 11:33 pm
by fairspares
Atomic spider , buzzsolo stock them £55.
Posted: Fri Oct 07, 2016 6:45 pm
by rosscla
Atomic spider was too short for my MBD crownwheel. Check it if you go down that route.
Posted: Fri Oct 07, 2016 7:50 pm
by fairspares
My road lamby has an af machined deeper sil crown wheel with atomic spider and mrb pressure plate and ive got the reedspeed 6 plate clutch fitted , i dont know how deep the mrb crown wheel is but the atomic spider is made for 5/6 plate clutch kits , in my sprinter engine i have a very deep tino crown wheel , atomic spider and mrb pressure plate and 7 surflex 2.5mm greens with 1.2mm steels.
Posted: Fri Oct 07, 2016 9:14 pm
by rosscla
Sorry I should have been more clear - the base of the spider didn't protrude from bottom of the sprocket. It would have locked up if tightened down.
Posted: Fri Oct 07, 2016 9:30 pm
by fairspares
rosscla wrote:Sorry I should have been more clear - the base of the spider didn't protrude from bottom of the sprocket. It would have locked up if tightened down.
ah yes i had this with the tino crown wheel but it was only slightly short , i removed a small amount from the crown wheel centre to stop it locking up.
