Page 1 of 2
Upgearing a P2
Posted: Tue Oct 04, 2016 2:23 pm
by fraserp200e
I've got one of my engines in bits at the moment and am toying with the ideal of upgearing it, more just for the sake of tinkering than anything else.
It's a Harry Barlow stage 4 with a Sip road 2 so currently it has bags of torque all through the rev range in all gears. Was thinking of upgrading the primary for something like this;
http://www.sip-scootershop.com/main/bas ... anguage=en
or even a 24/63 upgear kit. I've got a couple of exhausts to try as well as the Sip road 2 as well (Revolver RHS).
Worth it or not? Anybody else done this or do I need a beefier kit to pull the higher gearing? Would be interested to hear from anyone who's done it, good or bad.
Re: Upgearing a P2
Posted: Tue Oct 04, 2016 4:28 pm
by cartmel808
I'm running 24/63 up-gear kits on 2 different kitted p2 motors - ones a reed polini 221 & the others a reed malossi 221.
On the malossi I've had to swap the standard 4th for a 36t cog as it struggled to get into the power in 4th (even with 31hp & 23lb/ft)... but the lower revving polini kitted motor can pull the standard 35t 4th no bother at all...
Re: Upgearing a P2
Posted: Wed Oct 05, 2016 6:59 pm
by 1469leach
carmel808, can I ask if the polini is the new ish 221 kit used with a 60mm crank?I got that set up and think that my crank is messing up the induction of fuel before to power peaks.Which crank are you using with it mate.Sorry a bit off topic but i'm running 64/23 gearing with a longer 3rd and t5 forth ,final drive ratio 4.74-1 pulls gret when in the power band.
cheers Jeff
Re: Upgearing a P2
Posted: Thu Oct 06, 2016 8:34 am
by fraserp200e
Cheers for the info
Re: Upgearing a P2
Posted: Thu Oct 06, 2016 2:00 pm
by cartmel808
1469leach wrote:carmel808, can I ask if the polini is the new ish 221 kit used with a 60mm crank?I got that set up and think that my crank is messing up the induction of fuel before to power peaks.Which crank are you using with it mate.Sorry a bit off topic but i'm running 64/23 gearing with a longer 3rd and t5 forth ,final drive ratio 4.74-1 pulls gret when in the power band.
cheers Jeff
Yes - its the latest 221 kit & I'm running a scooter & service bell crank (reed valve)... rest of set-up is delly 30mm vhsh carb, vforce 4 reeds, pinasco flytech ignition, scooter & service pipe.
Re: Upgearing a P2
Posted: Thu Oct 06, 2016 8:07 pm
by 1469leach
Ok thanks for the reply, I've got nearly the same set up with a bell crank and a phbh 30 carb. Where yours is different is the pipe, reeds, and ignition. I be got static ignition , an rd350 reed and an RZ right hand pipe, it has a bit of a flat spot between 4600-5400 ish . Thought it was due to the low crankcase compression caused by the crank and it maybe that! Do you have the s&s new line pipe and does it cut in early on in the rev range?
Cheers Jeff
Re: Upgearing a P2
Posted: Thu Oct 06, 2016 9:02 pm
by cartmel808
Yes it's a Newline L/H.... comes onto pipe @ just over 3k and then peaks @ around 7k... exhaust port has been tweaked slightly to allow it to rev on a little more
Re: Upgearing a P2
Posted: Fri Oct 07, 2016 6:46 pm
by 1469leach
I think that is the main difference.What did you do with the exhaust port altogether?
cheers Jeff
Re: Upgearing a P2
Posted: Fri Oct 07, 2016 7:08 pm
by cartmel808
It was slightly widened... nothing drastic - only around 1mm in total & this was mor to accommodate the liger gearing than anything else...
Re: Upgearing a P2
Posted: Mon Oct 10, 2016 3:49 pm
by 1469leach
Thanks for that Carmel808, can you use a centre stand with the scoot and service pipe?
Cheers Jeff
