Page 1 of 2
LED headlight modules
Posted: Sat Sep 24, 2016 8:59 pm
by warts
The previous scooterotica discussion thread seems to have got itself lost, so I can't add this there. Here is some additional stuff people may find helpful.
https://www.amazon.com/Evitek-Headlight ... B017M566T4
Its is a 4500lumens unit. Consumption is claimed to be 40w, which should leave enough output to power other stuff.
The discussion goes on here
http://advrider.com/index.php?threads/d ... t-30427784 and post #32 shows the beam pattern on both high and low beam.
Google provided the amazon vendor address in the US, obviously they are all made in China where ever you get them from.
What is nice is that this one is cheaper than the previous one that was recommended to me. Still not dirt cheap, but within <this much> of a reasonable HID - maybe even just plug and play into an H4 socket.
Usual disclaimers - no afiliation,
Re: LED headlight modules
Posted: Sat Sep 24, 2016 10:16 pm
by Knowledge
Interesting. It is a shame that the Lambretta headlight socket is not already compatible (I know it can be modified to suit).
The thing is, that in a year or two, these lamps will be under £10 each.
Thanks for sharing.
Posted: Sat Sep 24, 2016 10:29 pm
by coaster
I would have liked to see the beam pattern on the road rather than against a garage door.
Posted: Sun Sep 25, 2016 12:37 am
by Minority
But look at the size! At 3.5 inches long I don't think you could get it to fit in a lammy headlight.
Posted: Sun Sep 25, 2016 8:16 am
by warts
The actual fitting surface is about 1/2 way along, behind that is the fan and control board. The forward projection is much the same as a halogen - its the same on most LED's, so as you would be changing the bulb holder anyway, would that still be an impediment?
Posted: Sun Sep 25, 2016 9:10 am
by Donnie
coaster wrote:I would have liked to see the beam pattern on the road rather than against a garage door.
this! I bet the "sharp cutoff" aint so sharp with a road beam pattern.
Posted: Sun Sep 25, 2016 10:25 pm
by Honeymonster
Also, the built in beam restrictor is for LHD cars to dip to the right.
Posted: Tue Sep 27, 2016 9:43 pm
by warts
The Cyclops LED module has no kick on dip, so the module has been designed to work for both LH and RH side riding.
I asked this AM, the guy got back to me this evening - shocking I had to wait 8 hours for a reply.
From this company
http://www.cyclopsadventuresports.com/3 ... _p_83.html
Posted: Wed Sep 28, 2016 8:04 am
by coaster
I have o doubt that this is a quality LED lamp but as with the HID units, they will only be effective if used in conjunction with a modern clear lens reflector. The Lambretta 'reeded' lenses will scatter the light all over the place. Also, the light output quoted in their spec is less than an HID and the current consumption is higher.
Posted: Wed Sep 28, 2016 8:05 am
by coaster
