sip speedo fuel gauge
Posted: Fri Sep 23, 2016 8:00 pm
by smoore-gt225
Hi Probaly a daft question but I think ive set up the speedo correctly does the fuel gauge show all white sections if full and each white section go out as it empties if you know what I mean
cheers steve
Re: sip speedo fuel gauge
Posted: Fri Sep 23, 2016 9:30 pm
by Tractorman
No, you should ride with the tap set on reserve and when the fuel level reaches the reserve the mileage readout will flash alternate with 'FUEL'. So there is no actual indicator of what's in the tank.
Posted: Sat Sep 24, 2016 8:40 am
by smoore-gt225
Tractorman wrote:No, you should ride with the tap set on reserve and when the fuel level reaches the reserve the mileage readout will flash alternate with 'FUEL'. So there is no actual indicator of what's in the tank.
thanks for reply but what was the point in incorporating a fuel gauge into the speedo than it says fuel gauge in instructions
I know the lammy ones flash
cheers steve
Posted: Sat Sep 24, 2016 8:49 am
by Tractorman
smoore-gt225 wrote:Tractorman wrote:No, you should ride with the tap set on reserve and when the fuel level reaches the reserve the mileage readout will flash alternate with 'FUEL'. So there is no actual indicator of what's in the tank.
cheers steve
Sorry, I did not realize Vespa ones are a bit more high-tect.
Posted: Sat Sep 24, 2016 8:56 am
by smoore-gt225
Tractorman wrote:smoore-gt225 wrote:Tractorman wrote:No, you should ride with the tap set on reserve and when the fuel level reaches the reserve the mileage readout will flash alternate with 'FUEL'. So there is no actual indicator of what's in the tank.
cheers steve
I think theres a lot more room to fit everything in. ive emptied the tank now to fit a fast flow tap so I will check it as I refill and see what happens too the gauges
Posted: Sat Sep 24, 2016 10:12 am
by Padge
all the bars light up white, when you get down to the last bar the fuel light should come on, then the last bar will flash
