Gear Selector Shaft wishbone alignment
Posted: Wed Sep 21, 2016 5:33 pm
Just hooking up the gear selector cables and arm on my LI series 3 restomod . With the gearbox in neutral when I fit the gear arm the gear arm bracket is at the limit of its range and hitting the casing as per the attached photo
When I rebuilt the box I thought I had followed the advice in stickies regarding positioning the gear selector arm but maybe I stuffed it up??
As it the later type shaft with integral gear arm then looking at stripping the box again if that's the case.
Sorry photos not great taken a night.
Any advice much appreciated.
Tippo
Sent from my EVA-L19 using Tapatalk
Tippo
