AC Ducati electronic kit no sidelights
Eean
Fitted an AC Ducati newstyle electronic kit from scootrr center. The purple wire from the switch is not connected to anything just taped up but wondering if that feeds sidelights on position 1 on the switch. All other lights work and it has a new electronic wiring loom. Ill check later for feed from purple wire but stuck lol
Nothing works on position 1 on switch, 1959 series1
Eean
Had a look on scooter help wiring diagram and the purple seems to go to the black wires, separate circuit?
Eean
Sorted, purple wire takes feed from brown on electronic loom to feed the sidelights
